Author Topic: 1966 230SL Head Removal  (Read 9433 times)
Re: 1966 230SL Head Removal
« Reply #25 on: December 02, 2018, 14:01:39 »
I am not competent enough to answer your other questions...
But: as for machining the head and then managing related offset vs. timing chain and overall timing work (valves, studs, rockers stc.) - the are a lot of threads on this forum and advise how to best go about it, including shimming of the camshaft pedestals (towers).
Harry
  • USA, TN, Knoxville
« Reply #26 on: December 02, 2018, 16:02:34 »
Great - the cam and supports are removed.  Thanks.
I was trying to check the vertical play in the vertical timing gear using the method that Joe suggested (in an old post) and it does exhibit some play but maybe not too much.   I wonder how much is too much?
I'm going to remove the VTG anyway so I'd probably have a better feel to examine the thrust bushing when I remove it.  Right?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #27 on: December 02, 2018, 18:40:34 »
That's showing the removal of a chain rail which is a different part but removal is similar.
Harry
« Reply #28 on: December 03, 2018, 01:40:32 »
Thanks Benz Dr - I didn’t know what was being pulled in the photo but I could see it was different.  I figured the photo was about the tool though.  Thanks!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
