Sorry, maybe I will add a word to help clarify...
Harry - this distributor (or rather rotor) position at this stage is only to verify that the crankshaft at zero is the "0" with TDC of the first cylinder is when the POWER stroke begins. That is all. You will adjust distributor exactly later, when you adjust ignition timing.
It is a four stroke engine. The crankshaft passes zero either when the piston in the first cylinder is starting power stroke or when it is starting a suction stroke. When you set the crankshaft at zero to set timing in engine, engine has to be at "0", meaning TDC when the power stroke in cylinder 1 starts. This is verified (that it is this "0", not the suction stroke 0) either by first cylinder cams positions (they have to be up, meaning valves closed, meaning power stroke starts) or by rotor position - spark given to cylinder 1, which is the rotor pointing more or less at the cut in the distributor housing. More or less, because if crank is at 0 for suction stroke, the rotor is pointing completely to the other side of distributor.
So orientation of distributor needs to be verified as it is important, as the experienced Members are saying, and rotor needs to point to the cut in the housing with distributor fitted in the right way. But the exact rotor location, a couple of milimeters this or that way is not that important at this moment.
What is also important now is the crankshaft at "0" exactly and the marks lining up on camshaft. Then for IP - you just turn the engine 20 degrees as described and you need to have all three marks on IP aligned (refer to Technical Manual). Even I did not have an issue wih tthat.
What I found important and I got help from the forum was how to re-assemble the chain tensioner properly with priming it with oil. There are threads about it and also it is described in Tech Manual.
If in doubt, the oriention of distributor is described in detail in Technical Manual for advance and retard types.
