Author Topic: Is the trunk semi-gloss or matt  (Read 2949 times)
johnk
  • USA, OH, Avon
« on: November 05, 2018, 04:37:15 »
I just finished painting my trunk with PPG 164 dark gray and I'm very disapointed
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
Re: Is the trunk semi-gloss or matt
« Reply #1 on: November 05, 2018, 04:41:18 »
sorry hit the wrong button.
The trunk is much shinier that the original and shows way to many flaws.  Isn't the finish suppose to be a mat finish?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Scottcorvette
« Reply #2 on: November 05, 2018, 05:53:31 »
I just painted some of my trunk/inner fender area with DB164, mine is in Glasurit 68 line paint. when I ordered mine I specified satin finish which is a semi-gloss. I also asked for it to be more matt than shiny and am happy with the finish. As far as I am aware the DB164 only denoted the colour and not the finish but don't quote me on that. I always work on the principle that unless you specify exactly what you want you will always wind up with someones else's interpretation of what you want and its invariably wrong...
If you aren't happy with the finish your paint supplier should be able to add a matting agent to dull it down. I believe you can also alter the finish by altering the thinner ratio but you'd need to check with your supplier.
As far as showing too many flaws then that means your substrate has too many flaws. Paint will only highlight what flaws are there and won't hide them, thats all in the preparation before hand and the cleanliness of your work area. No easy way round that one I'm afraid!
This picture illustrates that, I had just painted this area of trunk floor the day before. I had de-nibbed the primer with 320 grade foam backed paper then vacuumed it, then went over it with panel wipe, and then a tack rag and then painted it, there's still bits of dust in the paint just from atmosphere. This coat was just to get colour in some of the hard to reach areas though so it wasn't critical that it was completely dust free and was done in the workshop and not the spray booth so would have been impossible to get clean anyway.
When it comes time for the final topcoat in there everything will be completely clean, it will be in the paint booth which will also be clean, you could try dampening the floor down as well to keep the dust down. It's all in the preparation.
« Reply #3 on: November 05, 2018, 11:02:41 »
The flatting agent tends to settle.  Was it thououghly mixed?  Anytime I spray and semi or flat material I use a mixer that looks like a little squirrel cage blower on a drill and really give it a good mix.  My trunk looks like Scottcorvette's in terms of gloss.
johnk
  • USA, OH, Avon
« Reply #4 on: November 05, 2018, 14:41:40 »
Thanks Scott and Pat. I really appreciate the immediate reply. I just got back from the paint store and my problem may have been a little of both. I painted it late last night and I had the mixing ratio incorrect. I also wiped the trunk down completely several times and sprayed in my booth which seems to be otherwise working quite well. I don’t think I blew the dust out on the corners of the trunk as good as I thought.
I’m have a half of a pint of the paint left (90 bucks a pint -ouch). I’m going to skuff up and try a little again. Ifs it’s still too shiny I’m going back for another pint mixed to a lower shine. They didn’t want to add what I had left over as they didn’t know exactly how much matting agent to add.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #5 on: November 05, 2018, 14:45:27 »
Below is the soft top color. No dust but just looks a lot shinier than what I started with. This is before I respray it.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #6 on: November 05, 2018, 22:05:12 »
John,
Here is a photo that I took in the Bracq workshop last month of a trunk lid that he had just painted to give you an idea of a fresh paint job.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
johnk
  • USA, OH, Avon
« Reply #7 on: November 07, 2018, 08:56:29 »
thats the amount of shinr i was expecting. I will be repainting mine.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
perry113
  • USA, NY, Rensselaer
« Reply #8 on: December 06, 2018, 00:27:35 »
Absolutely gorgeous job!!!
Thank you for sharing!
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
mbzse
« Reply #9 on: December 06, 2018, 00:44:00 »
This is the way it looks coming from the Sindelfingen factory.
Albeit 50yrs ago...
/Hans S
