Author Topic: 230sl valve cover leak  (Read 2258 times)
dnadanny1
  • Hong Kong, North, Fanling, N.T.
« on: November 14, 2018, 04:07:57 »
HI there, i have a 1966 230sl, and i spotted a leakage problem at the valve cover seal.
No matter how  i tighten it according to the spec, it still leaks.
Any thoughts about this.
Thanks a lot.
William
Re: 230sl valve cover leak
« Reply #1 on: November 14, 2018, 06:01:47 »
Yup. Warped head and maybe the cover too. We used a piece of small O-ring and placed in the groove of the valve cove seal at each end so that each end would press down more than the middle. This may require a bit of experimenting to sort out. I would also check the top of the head to see how straight it is before you spend a lot of time trying to fix it.
« Reply #2 on: November 14, 2018, 12:44:09 »
Leaking from where exactly?
merrill
« Reply #3 on: November 14, 2018, 14:52:13 »
is it time for a new seal?
also make sure the seal is installed properly,
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #4 on: November 14, 2018, 23:36:50 »
When you bend and squeeze the valve cover seal and it shows cracked rubber - time to change the seal. Not a very expensive item. Do not overtighten the valve cover, you will bend the cover supports and this may cause noises.
