Become a
Full Member
Emergency Contact List
230sl valve cover leak
Topic: 230sl valve cover leak (Read 2260 times)
dnadanny1
Associate Member
Junior Level
Hong Kong, North, Fanling, N.T.
November 14, 2018, 04:07:57 »
HI there, i have a 1966 230sl, and i spotted a leakage problem at the valve cover seal.
No matter how i tighten it according to the spec, it still leaks.
Any thoughts about this.
Thanks a lot.
William
Associate Member
Platinum
Canada, ON, Port Lambton
Re: 230sl valve cover leak
November 14, 2018, 06:01:47 »
Yup. Warped head and maybe the cover too. We used a piece of small O-ring and placed in the groove of the valve cove seal at each end so that each end would press down more than the middle. This may require a bit of experimenting to sort out. I would also check the top of the head to see how straight it is before you spend a lot of time trying to fix it.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
1988 560SEC
Vendor
Platinum
United Kingdom, England, Richmond
Reply #2 on:
November 14, 2018, 12:44:09 »
Leaking from where exactly?
Stick
www.colinferns.com
merrill
Full Member
Platinum
USA, TX, Austin
Reply #3 on:
November 14, 2018, 14:52:13 »
is it time for a new seal?
also make sure the seal is installed properly,
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #4 on:
November 14, 2018, 23:36:50 »
When you bend and squeeze the valve cover seal and it shows cracked rubber - time to change the seal. Not a very expensive item. Do not overtighten the valve cover, you will bend the cover supports and this may cause noises.
