Author Topic: Where oh where does the trunk wire run  (Read 6740 times)
Tomnistuff
  • Canada, Qc, Levis
Re: Where oh where does the trunk wire run
« Reply #25 on: December 24, 2018, 23:11:35 »
When I restored mine, I found it had been cut as well to remove the trunk lid.  I found replacement cloth wrapped wire at ESPY a couple of years ago.
Tom Kizer
Levis, Quebec, Canada
« Reply #26 on: December 25, 2018, 10:35:46 »
I have my wire outside of the hinge.
When this thread started I figured I was missing the clips holding it, I had a trunk lid gromme that was not cut. Then I saw I am missing the grommets for license plate lamps, I ordered them and they came pre-cut.
No big deal, just an item to note/know.
« Reply #27 on: December 29, 2018, 13:38:02 »
Found the grommets:
1. The one in the trunk lid is listed under 82 ELECTRICAL SYSTEM, 55654 TRUNK LIGHTING as PN A 317 997 02 81, 1 pc required (about $3)
2. The ones in the rear cross panel for license plate lights are in 82 ELECTRICAL SYSTEM, 001 ELECTRICAL SYSTEM as PN A 113 997 03 81, 2 pcs required (about $5 per piece)
I do not know if the position 1 comes not pre-cut these days. Not sure if it is available from MB - the system does not show the availabilities until New Year. I cannot be sure about this part, as there is no drawing in the EPC, but I do not recall any other grommet there.
Position 2 comes pre-cut - those I recently bought.
It may also be that if you order position 1 these days, you get a replacement (position 2).
