Author Topic: "Red" Bosch Coil for 123 Ignition System  (Read 3034 times)
Atazman
  • USA, Ca, Pleasanton
« on: November 19, 2018, 21:57:35 »
I installed the 123 Ignition System back in 2010, and continued using my old coil which measured 1.5 ohms resistance.  Have had no problems whatsoever.
For those of you who installed 123 and changed to the "Red" Bosch coil.......did you see any benefit for the "Red" coil?
Thanks......
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
Mike K
    • Mike Kirkinis
Re: "Red" Bosch Coil for 123 Ignition System
« Reply #1 on: November 21, 2018, 05:51:23 »
I had a 123 system installed by Prestige Garage (an authorised 123 reseller) in Nice, 5 years ago. They installed the red coil, the reason given was that you can bypass the resistors with the red coil.
From the post below it appears that the 123 manufacturer recommends this as well, see reply#15:
https://www.sl113.org/forums/index.php?topic=23428.msg167802#msg167802
Mike
http://michali.zenfolio.com
