Author Topic: Dashpot Restoration or Replacement  (Read 3630 times)
RobSirg
« on: November 20, 2018, 23:57:21 »
Hi Guys,
My dashpot in the 280SL (Manual) is looking tatty. It doesn't appear they are available.
I see 'Benzrestorer' is selling them but the length of the rod appears too long - so might be for a different model.
Does anyone know if they can be replated without being damaged? (I assume they were yellow Cad originally?)
Worst case I can give it a manual polish in which case it will look more like Gal.
Thanks in advance
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
Re: Dashpot Restoration or Replacement
« Reply #1 on: November 21, 2018, 06:56:00 »
The plating process doesn’t damage the diaphragm.
Jordan
  • Canada, ON, Jordan
« Reply #2 on: November 21, 2018, 11:39:48 »
Rob, do a search for a dashpot for other manufacturers and you should find one the same size (diaphragm, rod end and threaded end).  Mine was missing when I bought the car and I ended up getting one for a North American car, same era.  Not at home at the moment so can't look it up and it was nine years ago.  The one I got fit and works perfectly.
Marcus
66 230SL  Euro 4 speed
RobSirg
« Reply #3 on: November 21, 2018, 12:09:56 »
Thanks Guys,
Yes I did see some for Buick's etc, but I think I will just have them plate it with my other parts.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mbzse
« Reply #4 on: November 21, 2018, 12:53:11 »
Quote from: Jordan
.../...a dashpot for other manufacturers and you should find one the same size (diaphragm, rod end and threaded end).../...
I have done the same, in some iterations the past decades. I can share some experiences: The various dashpot devices you can find on the market do have different "inertia" and spring force - they do not all share the same specification. But they look very similar on the outside if you put them side by side.
For your SL, you need something that has fairly soft dampening rate.
The dashpot has significant importance for the feel of shifting your gears, and for avoiding coughs in engine running when you rapidly let go of the accelerator (mounted on manual cars only).
The devices fail because the dampening diaphragm inside them ruptures
« Last Edit: November 24, 2018, 11:56:29 by mbzse »
/Hans S
RobSirg
« Reply #5 on: November 21, 2018, 13:46:48 »
Thanks Hans- this is good information.
I gather there is no physical way to check if the diaphragm is damaged?
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mbzse
« Reply #6 on: November 24, 2018, 11:54:33 »
Quote from: RobSirg
.../... physical way to check if the diaphragm is damaged?
The device will have a "limp" feel to it, when you press the pin.
If ok, you will hear a hiss from the dampening air cushion
/Hans S
RobSirg
« Reply #7 on: November 26, 2018, 23:24:38 »
Thanks Hans, yes, l can feel the diaphragm when l press the pin - will check for the same feel after plating.
Cheers.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
