Author Topic: Glove box rod  (Read 3382 times)
reg
  • Canada, BC, Victoria
Glove box rod
« on: November 22, 2018, 01:06:09 »
Having a problem.  Am missing the curved rod on the back of the glovebox.  I am getting ready for paint so this is the time to deal with it.  Any suggestions .   If I could get one it is the time to weld it on.   Maybe even a good photo and some dimensions so I could try and make one.   Any ideas?
WRe
Re: Glove box rod
« Reply #1 on: November 22, 2018, 07:53:16 »
reg
Re: Glove box rod
« Reply #2 on: November 22, 2018, 10:47:26 »
Thanks for the info.  I am looking for the curved rod that stops the door from opening to far.  Will deal with the spring issue later.
WRe
Re: Glove box rod
« Reply #3 on: November 23, 2018, 10:13:31 »
attached a picture with the rough measures.
...WRe
reg
Re: Glove box rod
« Reply #4 on: November 23, 2018, 14:34:34 »
Thanks for the diagram    I will give it a try.
dirkbalter
  • USA, CA, Corona
Re: Glove box rod
« Reply #5 on: November 23, 2018, 22:38:59 »
Here are some pics of mine. It broke during disassembly. Still need to clean the weld a bit.
The rod measures approx. 6 mm in dia.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
reg
Re: Glove box rod
« Reply #6 on: November 25, 2018, 21:02:25 »
Great pictures .    This will help a lot.
dirkbalter
  • USA, CA, Corona
Re: Glove box rod
« Reply #7 on: November 25, 2018, 22:25:06 »
If you are making the rod from scratch, let me know and I can make you a sketch with some additional dimensions.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
reg
Re: Glove box rod
« Reply #8 on: November 26, 2018, 02:30:26 »
That would help. I am going to make one from scratch,  will post a picture when I am done.
dirkbalter
  • USA, CA, Corona
Re: Glove box rod
« Reply #9 on: November 26, 2018, 17:30:22 »
Attached is a sketch, with dimensions coming from mine. It varies slightly from what Wre posted. You will have to test it with the door and the compartment  assembled prior to finishing (painting) it.
hope that helps.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
reg
Re: Glove box rod
« Reply #10 on: November 26, 2018, 21:12:39 »
Thank you .   Should be all I need.
Atazman
  • USA, Ca, Pleasanton
Re: Glove box rod
« Reply #11 on: November 27, 2018, 03:05:58 »
That is one nice drawing, Dirk!!
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
