Bali, I am not sure what version lower oil pan you are using. Here is some additional information. The latest version M130 engine and used a 7mm deeper lower oil pan (ribbed bottom and 13mm drain plug). Oil capacity was increased by 0.5 liter. A rubber extension was added to the oil pick-up for the increased depth in conjunction with the new style, deeper oil pan. All details and part numbers for this change are described, in detail, in the late BBB supplement (July 1973), p. 18-6/1 and 18-6/2 . During repairs early oil pans are normally replaced by the later deeper oil pan. Recognize the later lower oil pan by it's ribbed bottom and its 13mm head drain plug.
