Author Topic: 1971 280sl tach cable  (Read 2685 times)
Jgivoo
« on: December 10, 2018, 04:18:49 »
Newbie here. The tach started making noise recently. Disconnected cable on engine. Pulled out inner cable to inspect and now I can't get it back into the tachometer. Does the tach now have to be removed inorder to insert the inner cable into the tach? I have tried rotating the inner cable but I can't get it to slip into the tach.  Any advise would be appreciated.
WRe
Re: 1971 280sl tach cable
« Reply #1 on: December 10, 2018, 08:50:32 »
No, you don't need to remove the tachometer. It's possible to do it from underneath but you need a lot of patience and rotations.
...WRe
Jgivoo
« Reply #2 on: December 10, 2018, 11:21:01 »
...WRe
WRe
Thank you for your reply.  What do you mean by underneath?
WRe
« Reply #3 on: December 10, 2018, 12:01:34 »
sorry, from the engine side. I confused it with the speedo because in German the speedo is called tachometer.
...WRe
« Last Edit: December 10, 2018, 14:57:56 by WRe »
MikeSimon
  • USA, OH, North Royalton
« Reply #4 on: December 11, 2018, 19:42:10 »
If I read this right, you disconnected the tach cable at the engine and then pulled the inner cable out from the sheath?
And now you want to push the inner back through the sheath into the tach?
You may have to unscrew the outer at the instrument from under the dashboard, slide the inner cable back in and then reconnect to both ends.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Jgivoo
« Reply #5 on: December 12, 2018, 01:12:38 »
MikeSimon,
Yes. That was my biggest fear  of unscrewing outer ar tach.
Thank you
