Become a
Full Member
Emergency Contact List
General Discussion
Buds Benz AC Pulley Alignment
Topic: Buds Benz AC Pulley Alignment (Read 2897 times)
Alex D
Full Member
Silver
USA, NC, Cary
December 10, 2018, 19:44:18 »
Trying to help out a friend. Does anyone who installed the Buds Benz underhood air conditioning had any water pump pulley alignment issues? Belt is fraying after 300 miles.
Alex D
1967 250 SL
Original 140K mi
181 Light Beige, with 112 Turquoise Interior
wayne R
Re: Buds Benz AC Pulley Alignment
December 11, 2018, 03:06:19 »
Alex, i have not had A/C contacts with Buds Benz, but have with ignition etc,
and there service man, i think his name is Brad can be very helpful,suggest try him
some time,.
suavemechanic
Reply #2 on:
March 29, 2019, 00:20:51 »
Hi , just fitting my kit now and not much is lining up ! how did you resolve this ?
cheers Paulo
Alex D
Full Member
Silver
USA, NC, Cary
Reply #3 on:
March 29, 2019, 18:49:59 »
We are still working on it, getting close.
Alex D
1967 250 SL
Original 140K mi
suavemechanic
Reply #4 on:
April 23, 2019, 03:22:06 »
Hi progress update ...
I am having an 80/100 mm spacer made up ( 2 mm ) at the crank to match the water pump pulley
I used thick gasket paper to mock this up.
once that is set you can move onto the air cond belt ......
First i matched the idler pulley they sent to the air cond unit ( a bunch of washers did the trick )then bought a belt that actually fit.
I need about 2 more mm between the new double row pulley and the crank/ harmonic balancer .
I ended up spacing out the compressor (more washers )
the exciting thing is the power steering pump seems to have a floating shaft ,and it will slide out to match the new position nicely .
( please check this on yours to make sure my rebuild guy wasnt lying his ass off ! )
I can only assume buds have changed the compressors for something with a different ear, that has pushed the belts out , that was my next option , trying to machine back the ears (or remake that barbecue plate )
cheers and good luck
Last Edit: May 15, 2019, 00:51:28 by suavemechanic
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #5 on:
April 24, 2019, 02:50:07 »
Even adding a Sanden compressor on the stock bracket can be an issue, I must have unbolted the compressor 6 times to get it all lined up.
General Discussion
