Author Topic: Kuhlmeister AC ON/Off Light Indicator  (Read 1706 times)
vande17941
  • USA, CA, Irvine
« on: December 15, 2018, 17:25:36 »
I had the AC out 6 months ago to redo houses and all the good stuff but I didn't pay any attention.
The little green on/of indicator light is out all the sudden even though the AC is fine.
Anybody know if it's a readily available bulb or if its hardwired in, or anything else I shold know before I drop the unit down again?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Montreal V8
Re: Kuhlmeister AC ON/Off Light Indicator
« Reply #1 on: December 15, 2018, 19:31:42 »
  I replaced mine with a green LED, quite straightforward.
vande17941
  • USA, CA, Irvine
« Reply #2 on: December 15, 2018, 19:35:02 »
Any particular LED, voltage wise? Anything special that I should know about? Or any wiring or circuit board type of stuff? Thank you sir
Montreal V8
« Reply #3 on: December 17, 2018, 17:01:43 »
   Hi.    I just used a small 12 volt green LED from a local electronics store. I can't remember now what the installation involved, but it was quite simple, and I don't think any printed circuitry was involved. Once you gain access to the back of the control panel, I think you'll find what  you need to do.
