Author Topic: Glove Box Screw Help Needed  (Read 1949 times)
StevenF
  • USA, NY, Merrick
« on: December 30, 2018, 21:05:24 »
I need some assistance sorting through the correct screws for my 71 glovebox
I need to confirm the screws for the following :
1-4 screws that secure the hinge to the lid (External door of the glovebox)
2-4 screws that secure the box to the bottom of the dash
3-4 washers that go under those screws from above
4-the 2 screws that secure the inside top of the box to the upper dash
5-do the screws in #4 have washers?
Based on the new Portal---see below
Please notice where it mentions 6 ...6 of what???
A 000 766 20 06
KEY
FOR REAR LID AND GLOVE COMPARTMENT STATE LETTER OF KEY BITTING WHEN ORDERING
Quantity:  1
N 007981 004318
TAPPING SCREW
GLOVE COMPARTMENT WITH LID TO INSTRUMENT PANEL
Quantity:  4
N 007982 003209
TAPPING SCREW
Quantity:  2
N 007981 004325
TAPPING SCREW
Quantity:  2
A 000 985 10 62
WINDOW
Quantity:  6
1971 280sl
Red Metallic
Bamboo MB Tex
mbzse
Re: Glove Box Screw Help Needed
« Reply #1 on: December 30, 2018, 21:31:21 »
Quote from: StevenF
..../...Please notice where it mentions 6 ...6 of what???
A 000 985 10 62
WINDOW
Quantity:  6
These are thin conical washers.
They go on the screws that secure the glove compartment.
Two up, four down.
PS: To me, seems the word "window" in M-B Portal ought to say "washer". Mistake in database?
Window pane = Fensterscheibe
Washer = Scheibe      DS
« Last Edit: December 30, 2018, 21:45:28 by mbzse »
/Hans S
« Reply #2 on: December 30, 2018, 21:37:14 »
The "WINDOW" is translated in my EPC on line (not Part Info) as "washer". Without 100% certainty it may be the 6 counter sunk washers you need (for top and bottom).
You also need rivets and rubber buffers probably.
I am usually very careful when buying screws from MB as it is very likely that, particularly with N in the PN, you will get some standard screws, not necessarily looking the way you want them to look. But it is not expensive, so you can try.
Also: to me it looks like you need 4 (hinge) + 4 (bottom) + 2 (top) screws. It looks like 2 too many in your list. But I may be wrong. On some pictures I saw screws in the place where I have the rubber buffers - either a mistake or earlier cars had screws there.
