As Dirk has mentioned, if your car is a late 280 (70/71) and if it is a USA model and not EURO, installing a 123 per 123 instructions may not work if ALL your emissions equipment is not working.
There are ways of making the 123 work:
1. make sure all your emissions equipment works and use program per 123 instructions. (can very complicated and expensive)
2. Replace throttle body to older 280/250 model so vacuum is not constant, but only at idle and use program on 123 for distributor 051.
3. If you know what you are doing, plug the vacuum on your current throttle body and drill a port to match an older throttle body (euro model). the casting is already set-up for this, but needs a hole drilled and a simple brass nipple placed to hold the vacuum hose. You can also have this done by sending your throttle body to Gernold at SL-Tech who has done a few of these. I did my own.
I did option 3 and car runs so much better. Of course some will advise against modifying the throttle body. You decide after research or ship the throttle body to Gernold. I drilled precisely, matching my 250sl throttle body.
I tried to repair the emissions, but it much better to just by-pass it all. I left it all in place, just by-passed the vacuum system.
good luck,
