Author Topic: Cabin wiring loom routing  (Read 3073 times)
Minerva
  • Ireland, Connaught, Manorhamilton
« on: January 03, 2019, 15:04:57 »
Hi all.
I'm just putting back together a 230sl and wondering what route the rear loom takes from the rear bulkhead forwards. It is clipped the the floorpan or is it left loose? Any pictures would be great.
Keith.
specracer
  • USA, MA, Duxbury
Re: Cabin wiring loom routing
« Reply #1 on: January 05, 2019, 13:13:33 »
It runs down under the A pillar on drivers side, and down the door sill up against the vertical seam. It is covered by the silver scuff door sill trim.
EeVeeWee
« Reply #2 on: January 05, 2019, 14:31:51 »
Here you can see it at the left side of the picture.
Again something else.
EeVeeWee
« Reply #3 on: January 05, 2019, 14:38:42 »
And here underneath the door sill trim:
Minerva
« Reply #4 on: January 05, 2019, 22:51:45 »
That's absolutely great! Thanks to both of you, the old loom had been burnt previously  so had no idea if it went there or through the seat crossmember.
Thanks again
Keith.
« Reply #5 on: January 11, 2019, 23:32:52 »
Ireland.
Hello Keith,
Is your car LHD or RHD ?
Minerva
« Reply #6 on: January 13, 2019, 14:47:38 »
Hi Achim it's a lid 230.
Keith.
« Reply #7 on: January 16, 2019, 12:39:39 »
Dear Keith,
Ah, a left-hand-drive, right?
Thanks a lot, that's the piece of info I need.
Because I can help you with that ... but not with the routing of a RHD Pagoda.
Please see my next response
https://www.sl113.org/forums/index.php?topic=28631.msg206803#msg206803
Minerva
« Reply #8 on: January 19, 2019, 17:15:39 »
Thanks Achim, I'll put it in loosely and post a photo to see if you agree.
Keith
