Sadie, to the best of my knowledge (others, please correct me if I am wrong), clock and radio are not fused together.
Clock is fused with the fuse No. 1 that has power permanently. Here is info:
https://www.sl113.org/wiki/Electrical/FusesYou also have descriptions of fuses under your fuse box cover. Fuse No. 1 has power at all times, regardless of ignition key position and is powering devices that need power all the time (e.g. clock, courtesy light, trouble light socket, etc.).
As for the radio - in my post there was a summary of my findings. It looks like (unless others will say otherwise) that there were two wires in the harness running next to coolant reservoir - one powered permanently for automatic antenna, one powerd in accessory position in ignition switch for the radio. Factory or dealer installation was about using these wires and attaching them to fuses in the fuse box you mentioned. You should have those wires there unless someone cut them short while removing the fuse box. Then someone might have powered the radio from somewhre else, e.g. from fuse No. 1.
I am not sure what is on your picture, I am not that familiar with various versions of installation. I have something very similar in another place and it is just a wire connector.
