Author Topic: Crankcase breather hose on 64 230SL  (Read 3089 times)
Rick Katucki
  • USA, ID, Eagle
« on: January 04, 2019, 19:38:46 »
The 230SL I am "resurrecting" has a piece of hose that runs from the top of the valve cover and over the side of the motor.  It is open to the atmosphere.  There is a rigid tube that is plugged on both ends and looks to have run from the valve cover to a fitting on the intake manifold at the throttle body.  I have not yet addressed this issue but assume that the crankcase breather hose should be connected to the intake manifold via the abandoned (plugged) tubing. I assumed that the the breather was disconnected because it was somehow interfering with the engine.  There is not an obvious amount of blow-by at the open end of the breather tube when the engine is running nor oil smoke at the tailpipe. [/size]
BUT, yesterday I saw pictures of a 64 230SL on bringatrailer.com. Photos of the engine clearly showed the same crankcase venting modification as I have on mine.  Anyone know if this is an 'accepted' modification for that year model?
Rick Katucki
64 230SL
Manual
Idaho, USA
clunker
  • USA, NJ, Chatham
Re: Crankcase breather hose on 64 230SL
« Reply #1 on: January 05, 2019, 00:02:03 »
[ I am just reposting the original question in full size font / appears to be an html glitch ]
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
« Reply #2 on: January 05, 2019, 00:37:57 »
There were two types of breathers on the 230, one was a metal fixture from the rocker cover and the second was a rubber one.  See photos.
The metal fittings were the earlier ones mine is a ‘65 and still had it then they went to the rubber connection through the remaining years.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #3 on: January 05, 2019, 10:05:31 »
This is a close up of the later solution Garry describes.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: January 05, 2019, 13:32:28 »
..and here's an earlier one; production date of my 230sl is Apr '64
Rick Katucki
  • USA, ID, Eagle
« Reply #5 on: January 05, 2019, 19:45:52 »
Thank you for the photos. I will gather the parts and set it up correctly. Curious to know how it will affect the engine as I don't know why it was altered in the first place.
Rick Katucki
64 230SL
Manual
Idaho, USA
« Reply #6 on: January 05, 2019, 20:26:27 »
You ay want to read this passage on the venting: https://www.sl113.org/wiki/Engine/Lubrication#ValveCover
