Author Topic: Switched vs. Unswitched Radio Power  (Read 4587 times)
tdun824259
  • USA, NE, Grand Island
« on: January 29, 2005, 15:30:52 »
I'm replacing (but keeping) my becker radio.  For those of you who have done this what is the best and most conveinent sources for switched and unswitched power.  I've also added a new power Hirschmann antenna that I've connected to the glove box compartment. That seems to work fine.  I can't find an unswitched power source for the new receiver to retain it's memory.  I've tried the clock (should have constant power) but no luck.  Any ideas from the group would be appreciated.
Tim Dunagan
1971 280 SL
Re: Switched vs. Unswitched Radio Power
« Reply #1 on: January 29, 2005, 15:44:51 »
Fuse #1 is always powered.
« Reply #2 on: January 29, 2005, 16:22:42 »
Hi Tim,  Your car should have a small fuse box located in the engine compartment along the passenger side fender near the radiator over flow tank.  I think the box has two fuses at least one of which is specifically for the radio.  Most power antenna that I have seen have a ground and two power inputs.  One input is always +12V and the other is switched power from the radio.  I think the second fuse in this box could be used for the antenna.
tdun824259
« Reply #3 on: January 30, 2005, 20:40:23 »
Jeff,
thanks for the heads up on the fuse box.  works great and sounds great too.
Tim D
1971 280 SL
