I have a squealing tachometer cable (hopefully), and got a GEMO cable to replace it. The cable is obviously not 'symmetrical' in that one end has a fixed plastic sleeve (~ 4 inches long) just after the fixing 'nut' and the cable is packed with grease, while the other end has no plastic sleeve and is not packed with grease. I am thinking that the sleeve end with grease attaches to the tach, and the other end goes to the drive on the front of the block. I figure you would not want the less flexible, greasy bit pointed down into the block, but then I've been wrong more than a few times before....
Can someone tell me the correct orientation for the cable? Evidently you can get it in backwards, and of course there are no instructions (not even in German....).
thanks -- Roger
