Author Topic: Radiator for 230SL  (Read 7778 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Radiator for 230SL
« on: February 04, 2019, 20:20:10 »
hello all, looking for a new old stock (NOS) radiator, part no. 113-500-06-03. If you have any ideas or leads, I'd sure appreciate it.
thanks,,
« Last Edit: February 08, 2019, 00:08:15 by Charles 230SL »
Re: Radiator for 230SL
« Reply #1 on: February 04, 2019, 20:37:04 »
Auto or standard?
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: February 04, 2019, 21:52:31 »
its a standard shift, thanks
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #3 on: February 05, 2019, 02:59:29 »
I have used radiator, untested, for manual transmission. Let me know if you would consider via PM.
Igor
KevinC
« Reply #4 on: February 08, 2019, 17:00:26 »
If Igor's radiator doesn't work out try Gernold at SL Tech...
http://www.sltechw113.com/parts.html
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #5 on: February 09, 2019, 00:44:01 »
thanks Kev, I just sent Gernold an email.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #6 on: February 09, 2019, 04:38:41 »
I don't anticipate much luck finding a new (NOS) radiator so looks like I'll need to get mine re-cored.
Bud's Benz sells re-cored 'high-efficiency' radiators; https://www.budsbenz.com/catalog/230-250-280-sl/f-cooling/F232-001A.
Anyone in this group tried one of these?
Jordan
  • Canada, ON, Jordan
« Reply #7 on: February 10, 2019, 12:35:20 »
You should be able to get yours re-cored for a lot less money.
Marcus
66 230SL  Euro 4 speed
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #8 on: February 10, 2019, 13:58:19 »
I had mine re-cored for $400.  The untested used ones I found were all close to $1000.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Vander
  • USA, OH, Columbus
« Reply #9 on: February 10, 2019, 23:42:49 »
I agree, $400-500 is probably the going rate for re-core. They paint it too, making it look brand new.
« Reply #10 on: February 11, 2019, 02:26:13 »
Just in the process of recoring mine in readiness for its 10,000 mile drive in the USA in a few months time.  I hope it is only 4-500 dollars
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #11 on: February 11, 2019, 03:29:54 »
you guys probably think I'm nuts but my primary concern is how the radiator fits after it's re-cored.
My present radiator fits perfectly between the baffle plates and if the tanks and brackets are not aligned/soldered correctly around the new core, I'll have to bend the baffles to accommodate the misalignment. I also have AC on the car and the condenser coil is mounted to the baffles.
I was hoping that whoever does the re-cores for Buds' would have done enough W113 radiators by now to know how to get it right the first time. I'm probably being too picky..
Atazman
  • USA, Ca, Pleasanton
« Reply #12 on: February 11, 2019, 03:59:36 »
Just had mine re-cored and I had the same concerns.  Like you, I have A/C, so the fit has to be right.  Unless you are having them install a "thicker" core you will be fine.  I believe any competent radiator shop will make sure the critical dimensions are held tight.
Oh...... mine fit perfectly and I hope yours does too.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #13 on: February 12, 2019, 00:09:59 »
thanks Don, that's good to hear.
I dropped the radiator off today and I'll keep my fingers crossed. thanks, Charles
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #14 on: February 17, 2019, 01:46:24 »
just an update,,,I picked up my re-cored radiator yesterday and it looks and fits great. The radiator shop installed a 3-row core and the total cost was $477.00 - not too bad.
Atazman
« Reply #15 on: February 17, 2019, 16:12:45 »
Great, Charles!  Thanks for the report.
Don
67 250 Sl
(#3168) from Italy
Jordan
« Reply #16 on: February 17, 2019, 20:02:41 »
You should get better cooling from the 3 row as well.  I know I did, but then I also replaced the water pump so that may have helped as well.
Marcus
« Reply #17 on: February 17, 2019, 22:28:38 »
Some things are best rebuilt and other things are best replaced with a new part. Of course, most of this has to do with how serviceable any given part might be. A steering box you would have rebuilt; a drag link, not on your life.
Same thing goes for chrome plating. Door handles you would re-plate and a trunk star you would buy new. You can certainly have a used trunk star plated and it will never look right because all of the sharp edges will be removed during the buffing process. Much of this is a mater of cost and availability of any given part.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #18 on: February 18, 2019, 01:09:57 »
yes
« Last Edit: February 18, 2019, 15:40:32 by Charles 230SL »
x046866x
« Reply #19 on: July 08, 2020, 11:34:58 »
Folks; How close to the flex fan did you mount your radiator?  At first I thought the closest possible would provide the optimum air-flow when stopped, but then was concerned the flex fan would...well...flex and rub against the radiator.
Thoughts?
BTW: Re-core is definitely the way to go!  About $500 and looks brand new...and already has the various dings underneath from 55+ years of various rocks and curb shots!  (dings look better when re-painted)
« Reply #20 on: July 08, 2020, 13:48:47 »
The original radiator in my '86 Nissan 300ZX was plugged up and no longer letting coolant flow through. Stayed completely cold when the engine was hot. Rather than replacing it ($280 for a good quality new one) or having it recored, I decided to try and run Barnacle Buster through it for a few hours while still in the car (for these cars you have to remove the front end to get the radiator out). Barnacle Buster is a descaling solution that is used in marine engine cooling systems and I had a couple of gallons sitting around from having used it on our boat's caterpillar 3208 turbodiesel engines. It worked like a charm, no more overheating on the highway.
So I believe we replace or have radiators re-cored, when all that is required is just a proper cleaning to remove calcium and other deposits.
