Author Topic: WTB Gas Pedal Linkage - FOUND -  (Read 3613 times)
johnbrowder
« on: February 07, 2019, 21:05:17 »
As part of an engine swap project my prior mechanic installed a nonstock pedal assembly out of a later model C-class.  I want to go back to the original w113 setup.  All of my OEM parts are gone, so I need everything from the pedal on.  I will need to convert to a cable somewhere at the firewall to mate with the w124 engine.  Thanks!
« Last Edit: February 28, 2019, 21:54:05 by johnbrowder »
johnbrowder
Re: WTB Gas Pedal Linkage
« Reply #1 on: February 28, 2019, 21:53:27 »
Found what I needed at Bud's in Atlanta.  Thanks for looking.
John
m300cab
  • USA, Pennington New Jersey
Re: WTB Gas Pedal Linkage - FOUND -
« Reply #2 on: February 28, 2019, 22:12:41 »
ok, good luck
the 280se 6 cylinder is pretty much the same as the 280sl
Michael Parlato
