Author Topic: Need help with a hood prop on 1967 250 SL  (Read 1980 times)
rockingchairmotors
  • USA, PA, Coplay
  • 1-610-972-9694
« on: February 14, 2019, 00:11:42 »
Hello
Purchased my first 113 a few months ago.  A 1967 250 SL.  First issues (I'm sure of many) is my hood prop.  Mine is bent and doesn't hold the hood up.  When I open the hood it slams against the front fender.  I am not sure if pieces are missing.  Can someone post a picture of one working correctly and possibly a parts schematic of it.  Anyone have a possible source for another one.  I have not checked through Mercedes as of yet.  Thanks in advance for the help.
Jeff
MikeSimon
  • USA, OH, North Royalton
Re: Need help with a hood prop on 1967 250 SL
« Reply #1 on: February 14, 2019, 00:57:34 »
Jeff:
Others will probably be of more help, but I don't really understand the issue. The hood is being held up with a "torsion bar" which acts like a tension spring. Opening is limited by a band. You torsion spring - the long rod that goes across the inside of the hood and supports in a block on the left side - is probably not installed correctly. :-[
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: February 14, 2019, 01:32:28 »
The left side of the rod is fed forward into the hood frame. Secure all three of the plastic guides around the torsion rod. Next rotate the free end counter-clockwise. You'll see a small hole in the outside frame of the hood, You can use a "S-hook" to safely hold the loose end of the rod in place until you are ready to put work in the plastic guide below.
sandcrab59
  • USA, MA, Lunenburg
« Reply #3 on: March 14, 2019, 23:47:37 »
AS Joe mentioned. Make very sure that the S hook is a very heavy piece of metal.
I made mine from Old bed springs that were used back in the fifties.
A lot of you younger people probably don,t even know what the old bed springs look like.
Ask your parents or relatives that over 70 years of age.
It is dangerous if the s hook is made out of lite metal. It will spring back and cause serious damage to you.
Do you agree Joe?
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #4 on: March 15, 2019, 04:30:44 »
That right Tom.  You can injure yourself and damage the hood.
