with our official
Pagoda SL Group logo
from our official partner.
Fuel injectors early type vs. late type
Topic: Fuel injectors early type vs. late type (Read 3443 times)
paults1
Full Member
Senior
USA, FL, The Villages
February 15, 2019, 20:33:38 »
Will the late type Fuel injectors work ok in an early 230sl. Early type #A000 078 0723, #on the injector DC8C45R1. Later type #A000 078 1123,#on the injector DC8C45R2. Is there any consequences if I use the later type?
Regards, Paul '63 230sl
mbzse
Full Member
Platinum
Sweden, Stockholm, Stockholm
Re: Fuel injectors early type vs. late type
February 15, 2019, 20:49:02 »
Yes, you can install Bosch "R2" injectors in your Pagoda engine
As far as I know, the "R1" is no longer available.
Mercedes as a matter of fact do state that you should
not
mix R1 and R2 injectors in one engine
Last Edit: February 17, 2019, 14:40:59 by mbzse
/Hans S
PeterPortugal
Associate Member
Gold
Portugal, Faro, Lagoa
Reply #2 on:
February 16, 2019, 11:04:59 »
Well Hans, you surprised me there.
Due to their very different size and shape I did not think it was an option.
I shall bear it in mind if I come across a set for sale.
1963 220se Cabrio
1968 280se Coupe
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Reply #3 on:
February 16, 2019, 15:29:10 »
the R1 injectors have been replaced by R2 injectors, R1s are no longer available. They are more or less the same, afaik a slightly different spray angle.
As Hans mentioned only one type should be used, no mixing of both.
...WRe
mauro12
Full Member
Gold
Italy, Sicily, Messina
Reply #4 on:
September 24, 2020, 21:49:42 »
I have just bought a set of 6 brand new bosch injectors and the car run terribly. No idle , no acceleration and huge smoke.
I will put back the old one but honesty how is possible that a new injectors fail so badly? Maybe they are fake bosch?
Mauro Pisani
250sl 1967 5speed zf manual
