Author Topic: New temp sender probe doesnt' fit -- am I missing someting here?  (Read 3661 times)
gkrea1
The replacement probe has a 12.8mm OD.  The original is 12.0mm.  The opening into which the probe fits is 12mm ID.  The new probe sits proud of the opening blocking the threads from engaging.  The new probe alse has a shorter hex head and a noticeably longer threaded section.  Finally, the probe isn't attached to the threads.
Am I supposed to shove it in harder?  Is the threaded portion supposed to crust the top of the probe to create a seal?
FWIW, I don't see any for sale that look like the original.
Re: New temp sender probe doesnt' fit -- am I missing someting here?
« Reply #1 on: February 21, 2019, 04:38:00 »
Looks like the wrong one. Where did it come from?
gkrea1
« Reply #2 on: February 21, 2019, 12:49:58 »
A Belgian-based seller on eBay.
Is there a go-to source for these I should use for my second try?
« Reply #3 on: February 21, 2019, 15:28:59 »
Do you need just the bulb at the end or the whole temperature gauge?
ejboyd5
  • Southold, NY
« Reply #4 on: February 21, 2019, 23:42:13 »
Depending upon the vendor's willingness to accept a return and how much you have to lose if things go bad, you might try reducing the offending diameter.  Your picture indicates only an 0,8 mm variance and there may well be enough metal in the area so that a reduction will not compromise integrity. Before attempting any modification I would test the unit/gauge combination with heated water so as not to waste my time on bad components/
« Reply #5 on: February 22, 2019, 07:06:02 »
I think your unit looks like the bulb is a bit ot of center...
Perhaps one of the black scenarios may be it gets stuck in its hole...
Taleb
  • USA, NY, SPRINGFIELD GARDENS
« Reply #6 on: February 22, 2019, 10:39:37 »
Hi , it just happened with me last week , I graineded it the it fit perfect .
Good luck
gkrea1
« Reply #7 on: February 23, 2019, 02:41:17 »
Thanks for the advice, all.
I did test the assembly in the kitchen and it works perfectly.   I will see what can be done to massage the fit when I return to town next week.
