Author Topic: 230 SL rear brake adjustment rings  (Read 2567 times)
EeVeeWee
« on: February 22, 2019, 18:57:41 »
I don't know the right for it, but I guess adjustment rings will suit.
How are these mounted at the pins?
They have slit holes and fit tight at a part of the pin, but how are they originally secured?
There is quite a force at it because of the compression spring.
« Last Edit: February 22, 2019, 19:02:10 by EeVeeWee »
Again something else.
Re: 230 SL rear brake adjustment rings
« Reply #1 on: February 22, 2019, 20:01:47 »
Maybe this helps:
64 retainer
outer side of the shoe
65 washer
66 spring
67 washer
70 cotter pin
If you follow this link and get towards the end/bottom of the bearing replacement process - you will see pictures of the part you are looking at, I think.
https://www.sl113.org/wiki/DriveShaft/RearWheelBearings
EeVeeWee
« Reply #2 on: February 22, 2019, 20:04:59 »
Thank you for the help.
I'm aware of the order of the parts at the pin, but as you can see the ring is stuck at the pin.
And the spring is pre-tesioned, so how does it stay there?
« Reply #3 on: February 22, 2019, 20:16:59 »
I see - in the car we were working on it did not come off, it was one part with the backing plate if I remember correctly.
« Reply #4 on: February 22, 2019, 20:57:35 »
That part isn't supposed to come off - at least I've never taken one off or ever needed to. These things turn to adjust your brake shoes in or out and they require a bit of force to make them turn.
EeVeeWee
« Reply #5 on: February 22, 2019, 21:21:35 »
Yes I think they are pressed together just to stay in place.
I took them off anyway for rust prevention, so now I have to think about a trick to get them in place again.
« Reply #6 on: February 22, 2019, 21:34:38 »
Weld the cam to the pin?
Add material inside the hole by welding-like process (I do not know how would it be called in English - hardfacing?) and pressing? Or doing it to the pin.
Some kind of clip holding it in place?
Just thought starters.
« Last Edit: February 22, 2019, 21:44:17 by Pawel66 »
EeVeeWee
« Reply #7 on: February 22, 2019, 22:06:02 »
Thanks for helping.
Welding will cancel the anti-rust protection, but I will figure something.
