Author Topic: PPI Resources - Ft. Lauderdale, FL - References Requested  (Read 2511 times)
bobparr
Hi All,
I am in need of a pagoda expert who can perform a PPI for me in Ft. Lauderdale.  Any references to individuals or companies that have the expertise and experience to conduct the PPI is appreciated.
Thank you in advance.
R/Paul
Preparing to buy 1st Pagoda
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: PPI Resources - Ft. Lauderdale, FL - References Requested
« Reply #1 on: March 09, 2019, 10:23:13 »
Hi Paul,
I am sure someone in your area will let you know of a shop/indevidual that can provide help. Meantime have a look at a pre-purchase check list prepared by many of our Members over the years.
Good luck,
Dieter
Check here _—-> https://www.sl113.org/wiki/Buying/PrepurchaseEvaluation
KevinC
« Reply #2 on: March 11, 2019, 18:13:21 »
I should be able to assist. Do you want to PM me with the details?
dldubois
  • USA, FL, Pembroke Pines
« Reply #3 on: March 12, 2019, 13:06:58 »
I'm also in the area if needed.
Dana DuBois
1969 280sl
Pembroke Pines, FL
« Reply #4 on: March 13, 2019, 00:56:36 »
Body is everything.  a bad engine or gearbox will cost you.  A bad body will kill you.  You really need someone who knows our cars up down and sideways. In lieu of that get as many pictures of the sides of the engine compartment up high, The underside and the trunk floor as possible and post them here.  If the car is Euro Spec it is almost certainly rusty.  Even if you flew in Dan Caron or Joe Alexander the 2 or 3 thousand you spent could save you 50.
bobparr
« Reply #5 on: March 13, 2019, 03:49:59 »
Hi KevinC.,
Thank you very much for the offer.  If you send me a message at paulmlack67@gmail.com, I'll send you a PM on details.
Cheers.
R/Paul
bobparr
« Reply #6 on: March 15, 2019, 05:26:07 »
Dieter,
Thank you for the reference to PPI.  Appreciate it and I'll come in handy.
Cheers.
Paul.
bobparr
« Reply #7 on: March 15, 2019, 05:28:06 »
Shevgal,
Thanks for the emphasis and pointers.  I'll be sensitive to these points and work with experts to come to a decision.
Cheers, Paul
