Author Topic: Bare Metal Respray in UK  (Read 5923 times)
Gormanston
« on: March 10, 2019, 09:23:51 »
Hi, can anyone recommend a good place to get a bare metal respray for mu 1967 250SL please?
Re: Bare Metal Respray in UK
« Reply #1 on: March 10, 2019, 09:31:42 »
Hello and welcome
Pics of your car are required, obviously!
Is it prepped? Have a chat with Colin Ferns (has done mine)? If it's just a spray job, there must be any number of places you could go... I know folk who've had good experience with Chesterton Coachworks
Gormanston
« Reply #2 on: March 10, 2019, 09:38:20 »
Hi, the car has been repainted at least twice. It has signs of filler and has some nice rust spiders in a number of places. The car is never likely to be sold so would like have it done properly, hence wanting a bare metal job. I’m not looking for it to be a show car, as want to still use it, but want it to be as good or better than it left the factory.
« Reply #3 on: March 11, 2019, 09:29:36 »
If there's paint on it, there'll be rust under it somewhere!
And getting that priced is like asking how long is a piece of string.
GeeMerc
  • Australia, Victoria, Newtown
« Reply #4 on: March 11, 2019, 11:03:28 »
Hi
My belief for a bare metal respray it would be best to acid dip the car.   I know some are not keen on that approach.  Where I had it done, it was a two tank procedure one for paint removal and one for rust removal followed by a rust preventative procedure.  Since the car is dipped the rust is removed from areas that cannot be reached by other techniques.   Have attached photos of car after the dipping process.
1965 MB 230SL Auto RHD Blue Metallic 387H, parchment MB Tex
1973 MB 350SL Auto RHD Dark Red 542G
2009 MB E350 coupe
« Reply #5 on: March 12, 2019, 21:49:10 »
Stripping every last nut and bolt from a car and dipping it rather than a bare metal respirated will result in cost increase factor of 10.
silver surfer
« Reply #6 on: March 14, 2019, 07:51:09 »
Lots of good body shops out there but price will depend on what you want exactly and if you are happy to do some of the work yourself. If you want to save money you could strip the car of its chrome etc and even paint strip the car in readiness?
swood1
« Reply #7 on: March 14, 2019, 15:22:58 »
Interesting thread.  I have been working on my car body also, however I keep thinking to myself whether it would be just worth me getting it acid dipped and then just repair the metal that (hopefully), is left.....
It's not cheap though, especially if you want to have an electrophoretic coating afterwards which I believe is essential if you want to protect those inner box sections etc.
GeeMerc can I ask who did you use for the dipping process? Do you think it would still be suitable even though I have already repaired half the structural members of the car?
Regards
Steven
Chris_ATL
« Reply #8 on: March 15, 2019, 13:07:37 »
Is it expensive?
Agreed, there is a lot of work completely stripping everything down and removing each piece, and it will expose EVERYTHING which means you will have more metal to fix than imagined...
Around here it's about $2,000 for the unibody and an extra hundred for doors, bonnet, etc each
swood1
« Reply #9 on: March 25, 2019, 21:39:24 »
Similar to what you quote but it's not the inital dip that's the expensive part it's the additional dip after you have worked on the body and the additional coatings anti corrosion coatings that are applied after you have done all your repairs.
jameshoward
« Reply #10 on: March 26, 2019, 01:53:11 »
There's an outstanding sprayer on the A303 in sort of Salisbury way. Not cheap (did an E-type recently for about 14k) but his work is concours. I can't imagine a pagoda would be significantly less. He doesn't acid dip, but that is bare metal.
Let me know if you're interested and I'll send his details.
James Howard
1966 LHD 230SL
Gormanston
« Reply #11 on: April 19, 2019, 06:49:52 »
Thanks Jameshoward, I have had an estimate for the job but it starts at £35k and will be more if there is additional work, which there will be. This is from a specialist firm that does exceptional work, mostly on old Ferrari’s and Aston’s.  Can you give the details of the firm on A303 please.
mgmoore
  • United Kingdom, England, cheltenham
« Reply #12 on: April 28, 2019, 19:57:10 »
A great friend of mine that i worked with for many years is an outstanding painter based in Surrey. He's old school and has done many Pagoda's with me over the years. If you still require the job done then i can put you in contact with him.
Cheers,
Matt
