Author Topic: Clutch pedal  (Read 2559 times)
450sl
Clutch pedal
« on: March 11, 2019, 12:42:24 »
Hi All,
Wanted to change my  clutchslave cilinder and adjust my 280-70 pedal.
Seems my clutchpedal rests approx 15mm or  1/2'' higher than my brakepedal .
Can anyone confirm that this is normal? any comments?
Mark
Re: Clutch pedal
« Reply #1 on: March 15, 2019, 12:44:15 »
Hi, Mark,
They sit level on my car
Re: Clutch pedal
« Reply #2 on: March 15, 2019, 13:52:54 »
Mark,
There should be an adjustable bolt at the junction of the clutch pedal and clutch master.
Check that out, it's not a straight bolt, but an offset type.
You will find a similar one for the brake pedal too.
How does the brake pedal sit in relation to the gas pedal?
Walter
450sl
Re: Clutch pedal
« Reply #3 on: March 15, 2019, 14:43:48 »
Thanks Naj and Walt, for your kind reply.
Naj , i already suspected taht pedals should be even.
Walter , i found this adjustmentbolt nr 20 , but for the required 0.2mm clearance i am at the very end of its range.
Since i can feel no excessive play on the clutchpedal pivotpoints , i suspect rubber stop no 24 .
Or has someone a better idea?
Does anyone have the partnr of this rubberstop?
Mark
« Last Edit: March 15, 2019, 15:07:14 by 450sl »
