Author Topic: Installing rear axle how do I center in the mount?  (Read 1945 times)
erickmarciano
  • Canada, Quebec, montreal
« on: March 11, 2019, 21:12:59 »
Hi guys
Want to install my rear axle . What is easier? Should I install the center bolt in the mount or should I take the mount off the 4 bolts , install the center bolt then put back the 4 bolts?
Erick
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Installing rear axle how do I center in the mount?
« Reply #1 on: March 11, 2019, 22:54:42 »
Normally the center bolt is attached last. In fact there is a factory cone shaped tool which is place on top the vertical arm, to help center it into the hole while the rear end is raised into place. Once in place, the special cone tool is removed and the bolt is installed.
erickmarciano
« Reply #2 on: March 12, 2019, 03:23:49 »
Sorry was not clear I ment the center bolt in the trunk ( center mount)
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: March 12, 2019, 05:52:07 »
Yes, that is what I meant also.
