Author Topic: 4 Hole Rubber Sleve for Brake and Fuel line clamps  (Read 4308 times)
Bill Sgro
  • USA, FL, Bradenton
« on: March 14, 2019, 04:15:08 »
I have been looking for the 4 Hole Rubber Sleeve for the brackets that hold the brake and fuel lines that run the length of the car.  I see plenty of 3 hole sleeves but no 4 hole sleeves.  Are they available anywhere?
1970 300SEL 3.5
Dave H
  • United Kingdom, England, Durham
    • Dave H
Re: 4 Hole Rubber Sleve for Brake and Fuel line clamps
« Reply #1 on: March 26, 2019, 17:40:16 »
A1094760384     Google the part number, plenty of suppliers this side of the pond.
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
Jack Jones
  • Canada, ON, Milton
« Reply #2 on: March 27, 2019, 01:54:12 »
The part is available from any Mercedes dealer with a MSRP in the US of $8.50. This part was not available a couple of years ago but is now.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Bill Sgro
« Reply #3 on: April 13, 2019, 18:09:34 »
Thanks Jack.  My MB dealer here in Sarasota tried to order it and got the three hole one.  Do you have a part number?
1970 300SEL 3.5
Bill Sgro
« Reply #4 on: April 13, 2019, 18:18:06 »
That A1094760384 was a good number.  There is 1 in New Jersey and 1000 in Germany.  Thanks for the help!
1970 300SEL 3.5
« Reply #5 on: June 16, 2019, 13:06:22 »
About a year ago I checked with the Classic Center and the 4 hole was no longer available and was not coming back.  They are pretty limited as they are 1970-71 US spec only.   If you are still looking I would suggest trying to find someone with a water jet to cut them out of rubber stock.
« Reply #6 on: June 25, 2019, 23:23:19 »
As an alternative the 4th hole is for a plastic line that runs from the trunk to the engine.  In a pinch you "Could" use the three hole ones and clip the 4th line to one of the hard lines using the white clips that go between the rubbers.  They are still available.
