Well, I installed the electronic ignition, changed the coil to the recommended coil, changed and gapped plugs5 thou more and installed new spark plug wiring - could not get car to idle well , but reved fine. Noticed that I may have chipped the magnet (1864) so changed back to points, while I try to order a new part. Need to get car running so I can get it to the body shop. My question(s) - 1. I reinstalled the points and resistor, but not the plug wires, plugs and coil.
Car started fine, and idles well, If i leave everthing as is, will the points burn out and will I damage anything else?
2. On the coil side, postion 1, goes to the points and I had a green/black wire on it also. seems to make no difference if it on or not.
Thanks for any info, this site has been very helpful from trans shifting to window replacement (another story)
1969 280 SL
