Author Topic: Fuse rate (Amps) for Kühlmeister Aircondition wanted  (Read 3215 times)
MartinK
  • Germany, Hesse, Büdingen
« on: March 25, 2019, 11:19:39 »
Hei at all members.
I am on the way to do some wiring work on my 1965 230SL. My Kühlmeister A/C was electrically not proper installed. I found a broken "inline"- fuse holder under the dash. I want to do some new wiring with a better fuse holder inside the engine bay but I cannot find a hint which fuse rate the fuse should have. I want to use a relay that the main power for the A/C does not run completely over the ignition switch. Can you kindly supply me with an information or a data sheet concerning the necessary fuse ampere-rate? Thank you. Martin
450sl
Re: Fuse rate (Amps) for Kühlmeister Aircondition wanted
« Reply #1 on: March 25, 2019, 15:03:29 »
here you are
MartinK
« Reply #2 on: March 25, 2019, 17:29:20 »
hei, this is really great. Hope that it is similar to Kühlmeister. We will see. At least 25 Amps.... :o , talk soon, Martin
WRe
« Reply #3 on: March 25, 2019, 18:55:10 »
Hi Martin,
you can find some electrical details for A/Cs in workshop manual for later cars (1968).
...Wolfgang
