Author Topic: Is my fluid coupling transmission sound normal? We  (Read 2231 times)
Tom in seattle
  • USA, WA, Shoreline
« on: March 31, 2019, 00:51:55 »
My 250 SL whines a bit at lower speeds in 2 and 3 gear from start to about 2500 rom but the the sound goes away as rpm’s build until it shifts.  I don’t hear much sound in gear 4.  The whine eliminates as I lift off the throttle (no driveline pressure +\- ) but increases if I lift off completely.  Its not a loud sound but noticeable.  I don’t think the sound is coming from the rear end.  I have read threads which may suggest this is not abnormal as well. I obses about it and all other things that I think might be wrong. What do you think?
Tom Averill
1967 250 SL Auto Euro Spec
