Dear Gents,
I am the process of adjusting the Soft-top frame.
I have first, as advised on this forum, fit the hart-top which is now going on and of smoothly and the windows fit perfectly.
I have adjusted the soft-top frame to the windows. The upperpart of the windows is closing very nicely, but on both sides the back part of the window is far off, between 7 to 12 mm (0.27559″ to 0.4724″ inch). It is not possible to move the frame more forward as there is no space anymore.
In picture 1 I moved the chrome strip forward, showing the gap. Picture 2 shows there is no space to move the frame more forward.
What is the solution:
1. Is there a trick?
2. I could move the chrome strip (with the window rubber) and the strip on which the chrome strip is mounted forward (picture 3). There is however not enough frame metal, so I should weld a metal strip on the frame and drill now screw holes etc. Risk is that the KHM fabric soft top will not fit anymore.
Thanks for suggestion, kind regards, Peter
