Author Topic: Oil in the footwells  (Read 4133 times)
Ollie
  • Canada, Alberta, Red Deer
« on: April 08, 2019, 01:19:32 »
I just pulled my 1967 250 SL from winter storage and there is moisture in the drivers footwell that soaked up into the carpets!
My first thought  was water, but that seemed very unlikely in the dry storage facility with the soft top on. On further inspection it seems to be a light oily substance. I can not see any seeping from the clutch or brake pedals, so I am stumped. Any thoughts from the learned forum? Second to that, what would be the best way to clean the underpaying and carpets? Thanks.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Oil in the footwells
« Reply #1 on: April 08, 2019, 01:45:46 »
I once saw a 230sl with a little puddle of fluid in the drivers's foot well.  It turned out to be a tiny leak from the tube connection of the clutch reservoir.
The fluid traveled down the tube through the firewall and puddled in foot well.
Or maybe fresh rat urine?🤪🤪🤪
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: April 08, 2019, 03:25:53 »
Coolant from the heater hoses/core?
« Reply #3 on: April 08, 2019, 04:22:14 »
If it's oil corn starch works well to soak it up. Once dry it will vacuum up easily.
« Reply #4 on: April 08, 2019, 04:51:56 »
Yes, I agree with Cees, probably coolant. It is oily and clear.
WRe
« Reply #5 on: April 08, 2019, 06:24:03 »
I had it too and it came from a broken seal of the heater control valve. It dropped on my gas pedal and my toes, clear and oily.
...WRe
Ollie
« Reply #6 on: April 08, 2019, 16:47:44 »
Thanks everyone for your replies.
 So, next question is obviously is how do I go about to fix this? Is this something an amateur like me can attempt or is best left for a pro to tackle? Is there any advice or a play by play in the technical section of the forum to help me out?
WRe
« Reply #7 on: April 08, 2019, 17:20:14 »
it will be hard but remove the underdash panel under the steering wheel and follow the marks under the dashboard. You can check the heater control valve through the opening on the firewall:  https://www.sl113.org/wiki/Electrical/HeaterControlValve.
...WRe
Ollie
« Reply #8 on: April 10, 2019, 02:56:19 »
Thanks WRe, that is exactly what it is. I appreciate the help. (Does look like a finicky job!)
Paul & Dolly
  • i Car
« Reply #9 on: April 10, 2019, 08:20:39 »
Ollie
Just have a look here in the Technichal manual , lots of info there.
Put "Heater Control Valve" in the search section.
The o rings harden and then leak,
It is reletively easy to service it, but a bit fiddley.
Hope this helps
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
« Reply #10 on: April 10, 2019, 15:32:53 »
I would pressurise the cooling system and test for leaks that way.
Jowe
« Reply #11 on: April 10, 2019, 20:53:07 »
I had a similar experience the other day when I took my first spring ride. I got a splash on my foot and instant assumed it was a coolant leak from the heater core. Since i have an early 230, there isn't any opening in the firewall to check the heater valve. The only solution was to enter the cave under the dash. Eventually, I could remove the heater core. I will send it to a firm in Germany for refurbishment. I will report when it returns.
Johan
