Author Topic: Does this need a gasket or gasket maker?  (Read 1355 times)
CJHenderson
  • USA, AR, Benton
« on: April 08, 2019, 21:12:33 »
Getting ready to finish the rear axel and do I need a gasket or gasket maker for the bracket for the drive shaft receiver?
1950 MG-TD
Re: Does this need a gasket or gasket maker?
« Reply #1 on: April 08, 2019, 21:37:25 »
I use a sealer like Permatex gray  on that area. I noticed that your axle boot isn't installed correctly. The split should be parallel with the floor so that it's not under any tension when the axle tubes are fully extended.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: April 08, 2019, 22:04:04 »
Thanks for catching the error, much appreciated.
1950 MG-TD
