If it is red automatic trans fluid, it will have the potential to leak when stored for long periods of time. This is because the fluid coupler is slowly draining into the pan. It fills the pan higher than normal and usually takes about 2 months are more. It SHOULD not normally leak. But if your speedo housing seal leaks or weeps during regular operation, it will leak worse when the pan fills up. If your speedo housing seal is good, it shouldn't leak.
I replaced my speedo seal and no more leaks. There could be other sources of the leakage, but that was mine.
