Author Topic: New exhaust system. OEM or Stainless Steel?  (Read 4492 times)
silver surfer
« on: April 10, 2019, 06:46:00 »
Hi all.
Restoring my car and planning to replace the whole exhaust system. Should I get one from Mercedes or look for a Stainless system? I am in the UK so would be grateful for any recommendations of good UK manufacturers / suppliers.
Many thanks
Re: New exhaust system. OEM or Stainless Steel?
« Reply #1 on: April 10, 2019, 07:53:15 »
I put in a stainless system back in 2003 and never looked back. Love it, I bought it from Van Dijk in Holland.
WRe
« Reply #2 on: April 10, 2019, 09:56:24 »
my stainless steel exhaust is 10 years old and I had no problems at all. I think it's a little bit louder and rougher than a steel exhaust.
But the main problem with stainless steel exhausts is their lack of fitting accuracy especially of those cheap ones: https://www.sl113.org/forums/index.php?topic=27995.msg201522#msg201522.
...WRe
mercakungen
  • Finland, Central Finland, Porvoo
« Reply #3 on: April 10, 2019, 11:09:34 »
I will go opposite way and switch from stainless to OEM. I will keep the stainless system as a spare part for the future.
BR,
Matti
-70 280SL
-57 Continental MK II
-70 Plymouth AAR Cuda
ex:
-61 220SEb Coupe "Kompressor"
-61 VW Karmann Ghia Coupe
-53 VW T1 "Zwitter"
mbzse
« Reply #4 on: April 10, 2019, 11:52:31 »
Quote from: mercakungen
I will go opposite way and switch from stainless to OEM../...
Ditto. Mild steel exhaust for me, like originally fitted ex factory.
See for instance:
https://www.sl113.org/forums/index.php?topic=24399.msg174524#msg174524
/Hans S
« Reply #5 on: April 10, 2019, 15:37:24 »
Bare in mind that since these systems are all welded multi-componential systems the labour content in fitting the original is significantly higher than fitting a stainless system.
The original does sound better though, in my humble opinion.
Dudlow
« Reply #6 on: April 16, 2019, 16:55:42 »
Just had my stainless system removed, and a full new MB original system fitted from the downpipes backwards.
What a difference,  sounds wonderful. Much quieter and a much deeper sound. I'm probably imagining it but car seems to drive smoother as well.
Expensive, particularly as the old SS system looked fine, but worth it. Recommended.
« Reply #7 on: April 16, 2019, 18:37:15 »
Are the pipes from exhaust manifold down available at MB?
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #8 on: April 17, 2019, 11:48:54 »
I installed factory parts in 2009 and it still is in perfect condition.  I always let the car warm up completely if I start it so I don't have any moister left in the mufflers to cause rust.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
« Reply #9 on: April 17, 2019, 13:04:37 »
I was curious. I ordered the front pipe for 280SL a year or so ago. Never got NLA reply. Now I hear it should be here any day. I wonder if I get it...
Dudlow
« Reply #10 on: April 17, 2019, 13:18:36 »
All factory parts..
Rick
  • USA, NV, Gardnerville
« Reply #11 on: April 17, 2019, 14:20:11 »
I prefer OEM.   But-- I am also in California where rust is not an issue.   What will destroy an exhause system is running the engine for a short time without heating it up fully and then letting the car sit for an extended period of time. I always run the car fully to temperture and run it properly before parking it for an extended period.
« Reply #12 on: April 17, 2019, 14:47:42 »
A lot of the stainless systems do not have the "cross-over" feature at the front pipes. However there is so much labor and skill required to weld up one of these systems correctly, I like the idea of a permanent solution like stainless.
mbzse
« Reply #13 on: April 17, 2019, 18:50:34 »
Quote from: ja17
.../...the "cross-over" feature at the front pipes.../...
Read more for instance in this posting: https://www.sl113.org/forums/index.php?topic=20707.msg150036#msg150036
/Hans S
« Reply #14 on: April 17, 2019, 20:05:10 »
I was told recently that the front down pipes are not available from MB. I had to go aftermarket for that part with mostly ANSA for the remainder.
mbzse
« Reply #15 on: April 17, 2019, 21:26:34 »
Quote from: Benz Dr.
I was told recently that the front down pipes are not available from MB../...
Looks like confusing info. Indeed, the parts market is in something of a flux; parts come and go on the shelves of M-B warehouses.
However, it seems that today, according to the Classic Center M-B official website, the Part is readily available
« Last Edit: April 18, 2019, 07:18:39 by mbzse »
/Hans S
« Reply #16 on: April 17, 2019, 23:00:11 »
Maybe today but not a month ago. Sometimes we run into regional or country shortages until stock shows up. None of my regular suppliers had any at the time.
« Reply #17 on: April 17, 2019, 23:03:45 »
2 things.
The Pipes are NOT AVAILABLE. I just checked with the classic center for the 5th time in 12 months.
And Yes the cross over box does make a difference in performance, exhaust note, and fuel economy. If it didn’t MB would have never put it on the car.
« Last Edit: April 18, 2019, 15:31:17 by Tyler S. »
« Reply #18 on: April 18, 2019, 04:48:31 »
For a while now, head gaskets for 230/250SL haven't been available. A customer asked for one, which I had in stock, and then he told me he would look around to see if he could find one. Later he told me he bought one from the Classic Center. I found this odd because my own suppliers couldn't get one from them during the same time period but somehow he could for a really good price?
johnk
  • USA, OH, Avon
« Reply #19 on: April 18, 2019, 13:33:18 »
I was debating if I should put my rusty looking but solid exhaust back on my car when I am done with the restoration. They muffler is a fairly new from Mercedes. Perhaps I will try and have it sand blasted then treat and coat with ceracote (ceramic heat paint). Not sure this will last forever but seems much simpler than painting and installing a new system when they are available. Much cheaper too. I only plan on showing it for a year or so before I get rid of the trailer.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
doitwright
  • USA, IL, Willowbrook
« Reply #20 on: April 19, 2019, 02:57:50 »
I believe most exhausts rust from the inside out.
Frank Koronkiewicz
Willowbrook, Illinois
ctaylor738
  • USA, VA, Falls Church
« Reply #21 on: April 19, 2019, 21:38:33 »
A few months ago I put a Timevalve stainless system from the manifolds back on a 280SL.  Everything fit, no issues.  They have changed the muffler pipes so they take the Mercedes tips.  I like these systems because a reasonably talented amateur can adjust them to get the tips right and then tighten the clamps.  With the factory exhaust, you need a skilled installer who will take the time to line up the pieces, tack weld them, take the system off and finish the welding, then reinstall.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
lowpad
  • USA, CT, New Preston
« Reply #22 on: April 23, 2019, 03:00:21 »
Put a German-made stainless system on my 230 not long after I bought it there 20 year ago.  Still looks good.  Agree with the prior comment that it's a bit rough sounding, but I like that it has a more aggressive tone.
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
