Author Topic: Hose clamp correction  (Read 1877 times)
ctaylor738
  • USA, VA, Falls Church
« on: April 20, 2019, 23:33:37 »
I'm working on a very early, low-mileage, mostly original  280SL.  The upper radiator hose clamp has been replaced with a Norma stainless clamp.  I would like to send it out with a correct clamp.
What type to look for?  A winder-type? Or a flip-type? Or a screw-type?
The heater hoses have the 9 mm winders.
Thanks.
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
mbzse
Re: Hose clamp correction
« Reply #1 on: April 20, 2019, 23:52:55 »
This is original on an early 280SL
Beru flip type hose clamp for 9mm wide band
« Last Edit: April 21, 2019, 21:10:39 by mbzse »
/Hans S
« Reply #2 on: April 21, 2019, 00:39:56 »
There is also a picture in the BBB showing this clamp on the radiator:
ctaylor738
« Reply #3 on: April 21, 2019, 00:46:22 »
Gentlemen,  thank you.
CT
Chuck Taylor
1963 230SL #00133
Falls Church VA
« Reply #4 on: April 21, 2019, 01:59:09 »
Only place I have found them is Authentic Classics.
ctaylor738
« Reply #5 on: April 21, 2019, 13:23:23 »
About five years ago, I got a couple from the US Classic Center for my Fintail.
I have always wondered why Mercedes used flip clamps on the radiator hoses.  (Yes, I know I need to get out more.). Was it to make it easier to unhook the hose and make sure the block was filled when changing coolant?
CT
Chuck Taylor
1963 230SL #00133
Falls Church VA
