Author Topic: Signal stick  (Read 3176 times)
Henry52
  • Singapore, Central Singapore, Singapore
Signal stick
« on: April 21, 2019, 10:49:58 »
Hi, the black plastic piece at the tail-end of the signal stick is loose. This plastic piece is the part that has a switch to increase the speed of the windscreen wiper. I am not sure how to make it tighter so it will not drop off. Sorry I am not technical and may not be describing the problem well. Anyone had this problem before and fix it before?  I have been told to go buy a new signal stick that might cost me in excess of $650 which I find it hard to part for what seems to be not a big problem. Thanks
dirkbalter
  • USA, CA, Corona
Re: Signal stick
« Reply #1 on: April 22, 2019, 15:30:03 »
Assuming yours in not repairable, you can buy reproduction ones from the vendor below for less but I don't know how good they are.
https://oldtimer-ersatzteile24.de/Turn-Signal-switch-for-Mercedes-Pagoda-W113-250SL-280SL
The are also a few threads here on that topic.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Signal stick
« Reply #2 on: April 22, 2019, 17:25:28 »
Indeed, if you type in the search box top right corner of the forum page "wiper switch" or "wiper switch repair" you will find a lot of threads on how to open it, repair it and also where to buy it.
E.g. this one: https://www.sl113.org/forums/index.php?topic=28435.msg205377#msg205377
Re: Signal stick
« Reply #3 on: April 22, 2019, 18:21:46 »
Keep in mind that the 230 and late 250 /280 are different parts. What car do you have?
Re: Signal stick
« Reply #4 on: April 22, 2019, 18:50:22 »
Henry
As you are in Singapore, I suspect you might have a RHD drive car. Not sure, but likely. I have a vague recollection (reading on here) that the stalks are "sided" and that RHD are NLA nor made repro. I may be wrong on that and very happy to be corrected
