Author Topic: Steering wheel hard to turn  (Read 1703 times)
Babis
« on: April 25, 2019, 07:28:49 »
Hello to every one,
I face an issue the last 3 months with the steering wheel, doesn't work smoothly and needs more power to steer that used to feel! Additionally I've noticed some drops 5-8 cm diameter  (red oil) on the floor of my garage, coming from the pump and some minor drops from bolt-worm.
I went to the mechanic and told me that we must replace the pump and remanufacture the worm. And the cost will be up to 500-600 Euros.
Any suggestions? Ideas..?
Thanks in advance
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
Re: Steering wheel hard to turn
« Reply #1 on: April 25, 2019, 09:25:09 »
i think the advice you got from your mechanic is quite sound..... if you want a short term fix, if it will work, try a hydraulic fluid stop leak additive for power steering..... and top up fluid....
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
Babis
« Reply #2 on: April 25, 2019, 09:43:53 »
Σ´ ευχαριστώ αδελφέ μου
