Author Topic: rear view mirror gasket  (Read 3864 times)
« on: May 06, 2019, 16:57:12 »
On the early all chrome mirror there's a gasket that holds the glass in place. I don't see anything in my parts book so it's not a part you can get from MB. Anyone have any ideas or suggestions?
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: rear view mirror gasket
« Reply #1 on: May 06, 2019, 16:59:45 »
I think it may be glazing putty for glass.  I took one apart a long time ago and I think that was what was there.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
« Reply #2 on: May 06, 2019, 18:02:25 »
It could be but it kind of looks like some sort of gasket.
« Reply #3 on: May 06, 2019, 18:21:09 »
I took one apart a while back and that glazing just broke apart. I think I carefully applied a clear RTV silicone to hold it in.
« Reply #4 on: May 06, 2019, 19:08:34 »
That's what I was thinking we might need to do.
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #5 on: May 06, 2019, 19:13:40 »
Hi Dan
I took mine apart in August of 2011 and there's definitely a gasket of some kind in there. There was also a little tag that had a date stamped on it, and the date was consistent with the factory date for my car. My photos are too blurry to see the details, but I figured the gasket was original, because it had a lot of little cracks all around it.
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
« Reply #6 on: May 06, 2019, 19:27:36 »
Hi Dan
Yes, and it is your mirror we're talking about. ;D
Minerva
  • Ireland, Connaught, Manorhamilton
« Reply #7 on: May 06, 2019, 20:21:47 »
There is a gasket there I'll take a picture tomorriw as ive one apart fir rechroming.
« Reply #8 on: May 06, 2019, 23:45:45 »
Attached is a picture I took right after I disassembled the mirror. You can clearly see the yellowish material that held the glass in. It was hard as a rock and extremely brittle. In fact you can see some of the areas that are missing. It is some sort of putty in a ribbon form, not a preformed gasket. You can also see the date stamp on the plated part and says something.... 1964.
pj
  • 1965 230SL
    • my home page
« Reply #9 on: May 07, 2019, 05:52:23 »
Mine had the date stamped on a piece of paper. I always took it for granted that the stamp was authentic and original.
Peter J
DaveB
« Reply #10 on: May 07, 2019, 11:48:15 »
I agree with Brad and Wallace it seems very like a linseed oil-based glazing putty.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #11 on: May 07, 2019, 14:32:21 »
Interesting that the date code ended up on your paper and my metal part. Pretty close and I guess it was up to the inspector exactly where. That just goes to show that there is randomness in these sorts of things much like the paint inspection dots.
wayne R
« Reply #12 on: May 08, 2019, 11:23:52 »
Hi Benz Dr, This what you can use, first solution is ,i have forgotton what is called,
but it is the black very fine light canvas,with a sticky back that is used on convertible top
rubbers, i still have a good size roll from my days with Cadillac and Buick, cut with sissors,
to the size you need then peel off the paper back,its marvelous, infact im going to do my
rubbers on the Pagoda ft window surround rubber soon,its the original and it wears off to a
cream -white colour instead of instead should be black.
Second solution is  a very thin cork rubber base gasket that is less than 1/16 think,
apply  a fine layer of contact cement its also  very good.
Let me know if you require a couple of these  pieces for your mirrow,i could send them to you  regards.
« Last Edit: May 08, 2019, 13:19:06 by wayne R »
« Reply #13 on: May 08, 2019, 13:53:18 »
 Could you, perhaps, recall how is this glued fabric called? I would look for it and apply to the rubber seals on soft top. All I found was the grip band for bicycles, but it does not hold well.
mbzse
« Reply #14 on: May 08, 2019, 15:14:04 »
Quote from: wwheeler
Interesting that the date code ended up on your paper and my metal part.../... there is randomness in these sorts of things.../...
Just to be clear, there was not a "mirror manufacturing department" in the M-B factory, not today and not in the sixties. Mirrors were bought in from subcontractors such as "Reitter & Schefenacker" in Esslingen. This may be the reason behind the differences in date tag design.
/Hans S
wayne R
« Reply #15 on: May 08, 2019, 22:53:41 »
Hi Pawel and others,
Just found it ,the blackstick on --is called Adhesive backed bowdrill,
Available at ---Old buickparts.com----Cars inc.----Newjeysey,comes in 2.1/2 ,or 5/0 inch wide  5./0 ft long.
Go to  page  1930  to   1960 buick==door panels head liner etc,===group===14===page 135.
I used this years ago on many Buicks i restored and it is marvelous,hope this helps.
Cars phone number is--908-369-3666
« Reply #16 on: May 09, 2019, 04:07:06 »
Thanks Hans. I do realize that these were built by subcontractors and sorry my post was misleading. My point I guess was that you may hear - "Dates codes on chrome mirrors are ALWAYS on the paper tag"....When in fact here it is shown that it was stamped in different places and maybe by different subcontractors. Always and never are difficult words in the automotive restoration hobby. It seems there are as many exceptions as there are rules.
