Or maybe it is a W108 front spring. All those dimensions are in the small technical book, will see if I can find.
Dave, the front axle was fully in tact when I bought the car and I disassembled it myself. Definitely not the compensating spring! Possibly w108 springs! My free spring length is a good 20mm longer than the 387mm, thats why I wondered how the free spring length is measured. I'm leaning toward stiffer front springs anyway but would like the car to sit a cm or 2 lower if possible (no tyre wheel arch rub?) so I'll probably purchase the smaller size top and bottom rubber mounts. They appear to come in 6 sizes, 32.5mm, 30mm, 27,5, 25, 22.5 and 20mm. My current ones are 25mm - 1103250285.
Thanks for checking Dave
Now to see if I can purchase them locally for a fair price!!! Though purchasing non-MB might be frought with danger if there is confusion over the spring specs as per this discussion...thats why I'd like to know if anyone has any real life spring measurements (my spring thickness is as per spec btw at 15.6mm).
Joe
