Author Topic: Grease nipples W113  (Read 3547 times)
tojo123
Grease nipples W113
« on: May 11, 2019, 05:47:45 »
Can someone provide a list of what grease nipples there are on a w113 280SL? I think it is a total of 13 of them but what kind are there?
E.g. M6 1.0 or M8 1.25 - 0, 45 or 90 degrees etc.
Would much appreciate a reply, planning to order Febi Bilstein.
Best regards,
Tommy
Kutte
Re: Grease nipples W113
« Reply #1 on: May 11, 2019, 06:10:37 »
Hi Tommy,
there are different nipple:
M6x1,0 / M8x1,0 / M10x1,0
Straight and 45°
Kutte
tojo123
« Reply #2 on: May 11, 2019, 07:18:56 »
Thank you Kutte,
Do you happen to know how many of each
M6x1,0-0°
M6x1,0-45°
M8x1,0-0°
M8x1,0-45°
M10x1,0-0°
M10x1,0-45°
that is needed?
Any tips on from which supplier in Germany one could buy Febi Bilstein nipples from?
Best regards,
Tommy
WRe
« Reply #3 on: May 11, 2019, 07:51:37 »
see here: https://www.sl113.org/forums/index.php?topic=17463.0 and http://www.pagodenteile.de/info/30.htm.
- 20 for 230/250SL
- 18 for 250/280SL from 06/67
- 17 for 280SL late
...WRe
« Last Edit: May 11, 2019, 08:06:19 by WRe »
tojo123
« Reply #4 on: May 11, 2019, 08:43:32 »
The below information is what I found from the thread that you linked to. (230 SL)
9 x N071412 008100 Kegelschmiernippel (grease nipple) = DIN 71412-A M8 straight
7 x N071412 008200 Kegelschmiernippel = DIN 71412-B M8 angulate 45°
2 x N071412 006100 Kegelschmiernippel = DIN 71412-A M6 straight
(thereof 1+1 for 230-early and only 1 + 0 for 230-late to 280SL)
1 x N071412 006200 Kegelschmiernippel = DIN 71412-B M6 angulate 45°
Can someone confirm that the above information is correct for 280SL?
So there is no M10?
Best regards,
Tommy
« Reply #5 on: May 11, 2019, 15:11:18 »
It is great to have the specifics of the part but I wanted to look at where they are all located a bit difficult to tell from the pagodentreffe diagram (kind of blurry, and I am not able to read the German).
Early cars through 250 SL (not sure where the cut off is for this count)
Three grease nipples on each steering knuckle/king pin (from the 250 SL manual) at the front tires = 6 items (#8 on the diagram in the manual)
Two on the lower wishbone and two on the upper on each side = 8 items (#6,7,9 on the diagram in  the manual)
One on the intermediate steering lever = 1 (#10 on the diagram in the manual)
One on the front driveshaft joint = 1 (#12 on the diagram in the manual) Is this only for a manual car?
Two on the middle drive shaft = 2 (I think #13 on the diagram referenced to pagodentreffe)
Two on the rear differential = 2 (#13 on the diagram in the manual for my 250 SL - manual date - 6/67, #14 in the diagram reference in pagodentreffe)
Total = 20
Later cars lose the two on the middle drive shaft? after 6/67
To get to 18
My 280 SL (Sept 1969 build) has none on the steering gear lever and none and none on the front of the drive shaft = 16
It is an automatic, would the manual cars have the extra grease fitting on the front of the drive shaft?
Yes/no???
« Reply #6 on: May 11, 2019, 15:43:06 »
Hi Jon,  I think you should find one on the front drive shaft to lube the centering cross flange. Opposite the grease nipple is a small weep hole to expel excess grease.
WRe
« Reply #7 on: May 11, 2019, 17:24:23 »
attached some illustrative material. If somebody has corrections let me know or more and better pictures I can insert it to the doc.
...WRe
dirkbalter
  • USA, CA, Corona
« Reply #8 on: May 11, 2019, 17:40:35 »
...WRe
This is great. Thank you
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
tojo123
« Reply #9 on: May 12, 2019, 12:23:24 »
...WRe
Thank you so much WRe, exactly what I was looking for! Much appreciated.
Best regards,
Tommy
« Reply #10 on: May 12, 2019, 15:09:01 »
As far as I know, every 113 has a grease fitting on the front end of the driveshaft.
« Reply #11 on: May 13, 2019, 10:50:53 »
Have not take the time to check, will try to get to this weekend. Thanks for the info.
