Author Topic: Rebuilt Mercedes Benz 280 engine for sale.  (Read 4891 times)
mbebrim
  • Latvia, Lielvārde, Salaspils
« on: May 13, 2019, 19:08:23 »
SOLD
Fully rebuilt Mercedes-Benz M130.980E (2.8 - 2778 cm³) engine for sale, with "108 270 13 01" auto box (untouched). New oversize pistons, cylinder head overhauled, cylinder block honed, evened, cleaned and painted. Has been run and tested on a test-stand, all holes sealed and stored in dry storage for a few years. Crankshaft turns around by hand, can't be started due to a missing fuel injection pump and ignition distributor.
Used for “Riga Master Workshop” representative in classic car exhibitions Techno Classica Germany in 2011 and 2012.
Fits straight to:
280 SE Limousine 1968–72 108.018 M130.980 E
280 SE Coupé / Cab. 1967–71 111.024/5 M130.980 E
280 SL Pagoda 1968–71 113.044 M130.983 E (only difference is other camshaft and fuel pump adjustments)
Engine ancillaries present: PAS pump; Starter motor; Alternator; Exhaust manifold; Intake manifold, throttle body with linkage shaft, start enrichment injector; Thermostat; Fuel filter; Breather.
Engine ancillaries absent: Throttle body linkage - few rods and lower part at the engine block; Ignition distributor; Fuel injection pump with injectors and steel lines; Cooling fan.
Asking price 5500,00 EUR or 6200,00 USD. Sold as is. More detailed pictures and information available on https://www.rmw.lv/page/en/we-offer-motor-mercedes-benz-m130-280se-280sl.
« Last Edit: October 30, 2020, 11:37:34 by mbebrim »
Re: Rebuilt Mercedes Benz 280 engine for sale.
« Reply #1 on: May 13, 2019, 21:08:21 »
This automatic transmission will not work in a Pagoda.
mbebrim
« Reply #2 on: May 13, 2019, 21:31:25 »
You are right, it comes as an additive. Originally engine was from W111 coupe.
Desertpagoda
  • USA, AZ, Tucson
« Reply #3 on: May 25, 2019, 22:32:27 »
What a buy, if it can be verified!
kb
