Author Topic: Antenna Hole  (Read 2168 times)
m300cab
  • USA, Pennington New Jersey
Antenna Hole
« on: May 18, 2019, 15:54:01 »
does anyone know of a template for drilling an antenna hole?
or a good way of going about it.
i can feel an access area between the inner fender and the fender
from the underside.
I'm working on a 250SL 5 speed with no hole for the antenna.
ThankYou!
Michael Parlato
WRe
Re: Antenna Hole
« Reply #1 on: May 18, 2019, 16:52:03 »
attached a picture with the position.
...WRe
m300cab
Re: Antenna Hole
« Reply #2 on: May 18, 2019, 17:07:16 »
!!!Big Thank you!!!
Michael Parlato
mbzse
Re: Antenna Hole
« Reply #3 on: May 18, 2019, 17:41:08 »
Quote from: m300cab
.../...i can feel an access area between the inner fender and the fender
from the underside.../...
Picture of access area. Fender sheet metal is tinned in this area (scrape primer paint off) to ensure good antenna grounding. Photo courtesy of member 66andBlue
/Hans S
Delvis
  • Canada, British Columbia, Delta
Re: Antenna Hole
« Reply #4 on: May 24, 2019, 01:08:30 »
Double big thank you!
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
