Author Topic: WTB 113 with engine swap, Los Angeles  (Read 4238 times)
280sld
« on: May 25, 2019, 17:11:09 »
I have been tinkering around with the idea of owning a 113 or a 190sl with an engine swap and using it as a daily. My commute is very short and the car will stay garaged. This might also improve reliability, maintenance costs, etc.
Let me know if you have anything available. Im cash ready.
« Last Edit: May 25, 2019, 18:03:34 by 280sld »
m300cab
  • USA, Pennington New Jersey
Re: WTB 113 with engine swap, Los Angeles
« Reply #1 on: May 26, 2019, 18:03:52 »
they are very reliable to begin with
just switch to pertronix electronic ignition
and you are pretty maintenance free, change the oil, grease chasis, the usual
less headaches than a computerized car in my opinion
Michael Parlato
cydways
  • USA, CA, Avila beach
« Reply #2 on: May 31, 2019, 19:24:21 »
what kind of engine/trans swap are you looking for?
1966 230sl euro 4spd
1976 240d 4spd
1973 BB Corvette
1969 Roadrunner
1968 Jeep m715
1930 Ford Model A
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: May 31, 2019, 21:29:30 »
I wonder why you would want to swap the engine from a perfectly good car - the whole car is designed to work together and taking out an engine and replacing it with a (brand X- you choose) could cause you more headaches than you want.  If you are doing this as a hot rod thing than fill your boots but a well sorted pagoda should serve you well.   Unless you have had one of these you may not understand how well they are built and I was one of those who grew up with british cars, but those guys and gals in Mercedes Land did an amazing job with these cars.  This is not a simple plug and play like a GM-350 in a Jaguar sedan sort of swap.
I have found my time spent on fixing my car is due to switches that don't switch, perished rubber components like motor mounts and bushings and brake lines, fuel issues / rust .....but none of my issues so far have been "engine" related (touch wood).   Just for the record I have enjoyed 100% success on fixing items or replacing maintenance items.
I put about the same mileage on an annual basis on my Mercedes that I do on my 2005 Dodge Ram and I spend more time diagnosing and fixing my Dodge Ram (camshaft sensors, egr valves, etc).
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
MikeSimon
  • USA, OH, North Royalton
« Reply #4 on: June 02, 2019, 23:45:15 »
I believe the OP is thinking about putting a more recent/modern engine in a Pagoda or 190SL in order to make it more "reliable" and use it as a daily driver.
Biggest issue we all have with our cars is parts availability. May I remind the audience that currently, there are no head-gaskets available for later M130s. Just one example.
I know a guy who enjoys a Jaguar XJS as a daily driver because he fitted a Chevy V8 in it.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #5 on: June 03, 2019, 18:18:08 »
I'm guessing the clue is in the name - plans a diesel lump in a Pagoda...  ;)
