hello
this may be a 2 part question
I purchased a spark plug wire guide tube bracket for my car, the wires run inside the tube and then come out the bottom see photo
question is should i be able to run the wires in the tube with out removing the ends. I am talking about the 90 deg end that plugs into the distributor cap
if not, how can i remove an end of the spark plug wire to be able to run the wire in the tube and then re connect the end.
i may be over cautious here.
thanks in advance matt
