Author Topic: Radio power wire  (Read 2773 times)
m300cab
  • USA, Pennington New Jersey
Radio power wire
« on: May 30, 2019, 20:02:17 »
I dont see radio on the fuse box. Is there a specific fuse to get power to radio and which fuse did it come from...I'm working on a 250SL
Michael Parlato
mbzse
Re: Radio power wire
« Reply #1 on: May 30, 2019, 20:05:03 »
/Hans S
wayne R
« Reply #2 on: June 03, 2019, 13:31:50 »
Michael, i used  the small double fuse box on the passenger side
right by the radiator over flow tank,it is a hot  fuse ,even with ignition of,
as i like to use my radio with out turning ignition key,im not sure  if you have 280SL perhaps
it is different,look at bottom of photo, just see it. regards Wayne.
m300cab
« Reply #3 on: June 03, 2019, 14:46:02 »
Great, thank you for the guidance!
Michael Parlato
« Reply #4 on: June 04, 2019, 08:32:36 »
As stipulated in the post under the link Hans shared - you may have two wires in the harness - one for radio (powered when you turn the ignition key to accessory position or first position) and one for antenna - powered permanently.
They go to fuse box (link to supply in the post Hans provided link to) and through grommet in the firewall - to behind the dash.
